Старый 06.08.2020, 22:11   #1
25,475 / 846 (79) +++++++
Alexdmeyer: Issue with Revoking SysAdmin Role via OData in D365FO
Источник: https://alexdmeyer.com/2020/08/06/is...ata-in-d365fo/
I recently ran into an interesting issue with OData that I wanted to share. Within our Fastpath product suite we have a tool called Identity Manager that helps with the compliant provisioning, modification, and termination of user and user role assignments. Our clients use this module to help ensure that users are assigned the correct […]
The post Issue with Revoking SysAdmin Role via OData in D365FO appeared first on Alex Meyer.
littleax: Simple Rest API in D365FO, D365F, D365SCM Blog bot DAX Blogs 0 23.06.2020 14:12
Alexdmeyer: Easily Create a Read Only Role in D365FO Blog bot DAX Blogs 0 11.05.2020 22:12
Alexdmeyer: Does Licensing in D365FO Consider the Deny Permission? Blog bot DAX Blogs 0 07.10.2019 16:48
D365FO Platform Update 24 (7.0.xxxx) Issue 287129 bug fixes gl00mie DAX: Администрирование 0 15.02.2019 00:47
Часовой пояс GMT +3, время: 20:01.
