Старый 17.09.2019, 16:11   #1
25,475 / 846 (79) +++++++
ariste.info: Parse XML and JSON easily in MSDyn365FO
Источник: https://ariste.info/en/2019/09/parse...365fo-quickly/
Some time ago I had to create an interface between MSDyn365FO and a web service that returned data as XML. I decided to use X++’s XML classes (XmlDocument,  XmlNodeList, XmlElement, etc…) to parse the XML and get the data. These classes are terrible. You get the job done but in an ugly way. There’s a … Continue reading Parse XML and JSON easily in MSDyn365FO →
The post Parse XML and JSON easily in MSDyn365FO was first published in ariste.info.
dynamicsnavax: Data Management Export - XML to JSON Transformation Blog bot DAX Blogs 0 02.07.2019 10:11
ievgensaxblog: MSDyn365FO. How to Import CSV file using Electronic Reporting. Part 1 – Data Model. Blog bot DAX Blogs 0 06.02.2019 07:12
goshoom: XML response from OData services Blog bot DAX Blogs 0 26.04.2018 16:11
goshoom: Open API for JSON-based custom services in AX 7 Blog bot DAX Blogs 0 22.07.2017 14:17
Часовой пояс GMT +3, время: 18:32.
