Старый 15.02.2018, 09:11   #1
25,475 / 846 (79) +++++++
crmtipoftheday: Tip #1076: Add all assets to your solution
Источник: https://crmtipoftheday.com/1076/add-...your-solution/
A good observation from Nick “Benchpress” Doelman that, once you click Add All Assets when adding an entity to a solution, you won’t be able to remove any of the assets of that entity. Both, Add and Remove Components buttons will be gone.
The reason is fairly straightforward (though options could have been labelled better). Add All Assets does not simply mean “I want it all now!”, it implies the future as well, i.e. “I want it all now and forever”.
Add All Assets is like a super-vindictive ex-partner: gets all your assets after the divorce and still receives a slice of any future fortunes.
When Add All Assets option is checked, you no longer control assets of the entity, you just get them all. If someone else adds, say, a view, a form, or a field to the entity, you’ll get them in your solution as well. This is in a contrast with selecting some or even all components one by one where your solution won’t automatically get the future additions.
The components are easy to miss, make sure you test the solution export after crafting your selection. As Steve “Still an MVP” Mordue has pointed out, it’s possible to inherit some invalid attributes that would require a manual intervention.
crmtipoftheday: Tip #1060: Quickly create vector/SVG images for Dynamics 365 Blog bot Dynamics CRM: Blogs 0 24.01.2018 22:11
crmtipoftheday: Tip #1041: Make Dynamics 365 data import less rigid Blog bot Dynamics CRM: Blogs 0 11.12.2017 03:41
crmtipoftheday: Tip #1007: What is the Common Data Service (CDS) today? Blog bot Dynamics CRM: Blogs 0 23.10.2017 19:12
Navigate Into Success: Deploying control add-ins during development in NAV 2016 Blog bot Dynamics CRM: Blogs 0 13.11.2015 10:00
Часовой пояс GMT +3, время: 21:20.
