Filtering of lookup dataset may be done by two ways:
1)Globally - extend table links with used EDT by some BaseEnum, which will filter lookup dataset. It is like the links in Dimension table and her EDT
2)Locally - overload lookup method in your control (you must initialize system class for lookup, select the set of lookup fields and you may put some filter on your dataset in overloaded lookup method )
