Старый 15.07.2005, 00:33   #6
sukhanchik is offline
sukhanchik
Аватар для sukhanchik
3,342 / 3563 (125) ++++++++++
Say, my return procedure returns an integer:
Your procedure cannot return value (Transact-SQL ?).
Function can return value. If you use a function, I recommend to write:
PHP код:
        cmd.commandType(1);  //adCmdText, see ObjectBrowser in VBA
parameter "Parameter value";
cmd.CommandText(strfmt("SELECT spTestReturnRecordset '%1'"parameter));
as wrote Ace of Database, but do replace EXEC on SELECT
