Старый 01.05.2024, 14:41   #1
crmtipoftheday: Tip #1460: Loops and ThisRecord in low-code plug-ins
Источник: https://crmtipoftheday.com/1460/loop...-code-plug-ins
When you use loops like ForAll function in a low-code plug-in, ThisRecord will change its meaning from the table row associated with the plug-in run, to the row inside the loop. Disambiguating is fairly straightforward… once you know how.
(more…)The post Tip #1460: Loops and ThisRecord in low-code plug-ins appeared first on Power Platform & Dynamics CRM Tip Of The Day.
