Старый 07.02.2024, 12:11   #1
d365fokartik: Update NuGet Task version to 2.* D365 Finance and operations
Источник: https://d365fokartik.home.blog/2024/...nd-operations/
If Azure are using task version 0 and pipeline Build ending partially successful. You need to update task version and Command and arguments. Things to update. install -Noninteractive $(NugetConfigsPath)\packages.config -ConfigFile $(NugetConfigsPath)\nuget.config -Verbosity Detailed -ExcludeVersion -OutputDirectory “$(NugetsPath)”
