Старый 05.08.2023, 00:33   #1
How to get rid of a stuck report design in SSRS
Источник: http://alexvoy.blogspot.com/2023/08/...rt-design.html
It is difficult to say if your recent changes to an SSRS report design are really deployed. I suggest that any textbox be colored to visualize it (you can revert it in the end).
However, sometimes previous design is stuck on the server, and you still see no changes deployed, nevertheless, you already restarted Reporting services. Fortunately, there is a direct way to delete such a stubborn report from the server.
Open Report Server configuration manager as administrator and apply Portal URL setting if it is not done yet.
Then go for your report and delete it.
Next deployment should be OK.
