Старый 27.11.2022, 20:13   #10
Logger is offline
Logger
3,984 / 3273 (117) ++++++++++
Записей в блоге: 2
т.е. в целом все работает.
А из аксапты у меня не получилось.
Вот джоб
static void AotInspectWindows(Args _args)
    HWND            hwnd = 67552;
    // HWND            hwnd = 0;
    DLL             dllOleacc;
    DLLFunction     dllFuncAccessibleObjectFromWindow;
    Binary          guidBinary;
    // guid            guidXpp;
    Binary          ptrIAccessibleBinary;
    int             hResult;
    COM             comIAccessible;
    COMDispFunction comFunc;
    COMVariant      varChild;
    COMVariant      pszString;
    #define.OBJID_WINDOW    (0x00000000)
    #define.OBJID_SYSMENU   (0xFFFFFFFF)
    #define.OBJID_TITLEBAR  (0xFFFFFFFE)
    #define.OBJID_MENU      (0xFFFFFFFD)
    #define.OBJID_CLIENT    (0xFFFFFFFC)
    #define.OBJID_VSCROLL   (0xFFFFFFFB)
    #define.OBJID_HSCROLL   (0xFFFFFFFA)
    #define.OBJID_SIZEGRIP  (0xFFFFFFF9)
    #define.OBJID_CARET     (0xFFFFFFF8)
    #define.OBJID_CURSOR    (0xFFFFFFF7)
    #define.OBJID_ALERT     (0xFFFFFFF6)
    #define.OBJID_SOUND     (0xFFFFFFF5)
    Binary guid2Binary(str _guidStr)
        guid    guidVar;
        System.Guid guidNet;
        System.Byte[]  buffer;
        System.IO.MemoryStream  stream;
        Binary  ret;
        guidVar = str2guid(_guidStr);
        stream = new System.IO.MemoryStream();
        // stream.Write(guidVar);
        guidNet = guidVar;
        buffer = guidNet.ToByteArray();
        // infoCon(["length", CLRInterop::getAnyTypeForObject(buffer.get_Length())]);
        stream.Write(buffer, 0, 16);
        // info(ClrMethod_MRC::toString(stream));
        // info(ClrMethod_MRC::toString(stream.get_Length()));
        ret = Binary::constructFromMemoryStream(stream);
        // info(ret.xml());
        info(int2Hex(ret.byte(0), 2));
        info(int2Hex(ret.byte(1), 2));
        info(int2Hex(ret.byte(2), 2));
        info(int2Hex(ret.byte(3), 2));
        info(int2Hex(ret.byte(4), 2));
        info(int2Hex(ret.byte(5), 2));
        info(int2Hex(ret.byte(6), 2));
        info(int2Hex(ret.byte(7), 2));
        info(int2Hex(ret.byte(8), 2));
        info(int2Hex(ret.byte(9), 2));
        info(int2Hex(ret.byte(10), 2));
        info(int2Hex(ret.byte(11), 2));
        info(int2Hex(ret.byte(12), 2));
        info(int2Hex(ret.byte(13), 2));
        info(int2Hex(ret.byte(14), 2));
        info(int2Hex(ret.byte(15), 2));
        info('');
        stream.Close();
        return ret;
    dllOleacc = new DLL('oleacc.dll');
    dllFuncAccessibleObjectFromWindow = new DLLFunction(dllOleacc, 'AccessibleObjectFromWindow');
    // [url]https://learn.microsoft.com/en-us/windows/win32/api/oleacc/nf-oleacc-accessibleobjectfromwindow[/url]
    // HRESULT AccessibleObjectFromWindow(
    // [in]  HWND   hwnd,
    // [in]  DWORD  dwId,
    // [in]  REFIID riid,
    // [out] void   **ppvObject
    dllFuncAccessibleObjectFromWindow.arg(
        ExtTypes::DWord,   // [in]  HWND   hwnd,
        ExtTypes::DWord,   // [in]  DWORD  dwId,
        ExtTypes::Pointer, // [in]  REFIID riid, // TO DO
        ExtTypes::Pointer  // [out] void   **ppvObject  // TO DO
    guidBinary = guid2Binary('{618736E0-3C3D-11CF-810C-00AA00389B71}'); // IAccessible Interface // [url]https://learn.microsoft.com/en-us/dotnet/api/accessibility.iaccessible?view=windowsdesktop-7.0[/url]
    // guidXpp    = str2guid('{618736E0-3C3D-11CF-810C-00AA00389B71}');
    ptrIAccessibleBinary = new Binary(8);
    ptrIAccessibleBinary.qWord(0, 0);
    ptrIAccessibleBinary = new Binary(4);
    ptrIAccessibleBinary.dWord(0, 0);
    infoCon(["ptrIAccessibleBinary = ", ptrIAccessibleBinary.dWord(0)]);
    dllFuncAccessibleObjectFromWindow.returns(ExtTypes::DWord); // HRESULT
    hResult = dllFuncAccessibleObjectFromWindow.call(
        hwnd,
        #OBJID_WINDOW,
        guidBinary,
        // guidXpp,
    infoCon(["hResult = ", hResult]);
    if (hResult)
        infoCon(["LastError = ", WinAPI::getLastError()]);
    // infoCon(["ptrIAccessibleBinary = ", ptrIAccessibleBinary.qWord(0)]);
    comIAccessible = COM::createFromInterface(ptrIAccessibleBinary.dWord(0));
    // comFunc = new COMDispFunction(comIAccessible, "get_accName", COMDispContext::PropertyGet);
    varChild  = COMVariant::createFromInt(0, COMVariantInOut::In); // CHILDID_SELF
    info(any2str_MRC(varChild.variantType()));
    // pszString = COMVariant::createFromStr('', COMVariantInOut::Out_retVal);
    pszString  = new COMVariant(
        COMVariantInOut::Out_retVal,
        COMVariantType::VT_BSTR);
    // comFunc = new COMDispFunction(comIAccessible, "accName", COMDispContext::PropertyGet);
    // hResult = comFunc.call(varChild, pszString); Метод "accName" в COM-объекте класса "IAccessible" возвратил код ошибки 0x8002000E (DISP_E_BADPARAMCOUNT), который означает: Число аргументов, указанных в вызове функции, отличается от числа аргументов в объявлении метода.
    // comFunc = new COMDispFunction(comIAccessible, "get_accName", COMDispContext::Method); // Метод "get_accName" не поддерживается интерфейсом Automation COM-объекта класса "IAccessible".
    comFunc = new COMDispFunction(comIAccessible, "accName", COMDispContext::Method);
    hResult = comFunc.call(varChild, pszString); // Метод "accName" в COM-объекте класса "IAccessible" возвратил код ошибки 0x80020003 (DISP_E_MEMBERNOTFOUND), который означает: Запрошенный метод не существует или во время вызова была осуществлена попытка присвоить некоторое значение свойству, доступному только для чтения.
    // comIAccessible.accName(varChild, pszString); // пустая строка
    // comIAccessible.get_accName(varChild, pszString); // ошибка
    info(pszString.toString());
    info(pszString.bStr());
Вызываю AccessibleObjectFromWindow
получаю интерфейс IAccessible
дальше непонятно как из аксапты вызвать на нем метод.
Попробовал через Com - он даже его видит, но что-то с числом параметров ругается.
Натравил на oleacc.dll мастер оберток com объектов в аксапте. А он видит интерфейс IAccessible но обертку делает пустую - т.е. не видит ничего в нем, нет свойств и методов. И это странно.
Последний раз редактировалось Logger; 27.11.2022 в 20:28.
