Старый 31.03.2022, 18:11   #1
daxrunbase: Data histogram equalization
Источник: https://www.daxrunbase.com/2022/03/3...-equalization/
The Document Attachments were stored in our AX 2012 database, and were occupying several hundred GBs. As part of the migration to D365FO we had to export these files in bulk. The most efficient way is to run the batch task in parallel. But this data is tilted in a way that if you would [...]
The post Data histogram equalization appeared first on DAXRunBase.
