Старый 28.10.2021, 01:20   #1
Alexdmeyer: Using TPF to Protect Sensitive Data in Grid Columns for D365FO
Источник: https://alexdmeyer.com/2021/10/27/us...ns-for-d365fo/
I’ve covered the topic of the Table Permission Framework previously but wanted to give an example of how it can be used for protecting columns within grids in D365FO. Scenario There is a form within D365FO that contains a grid that has a sensitive data within a particular column that you would like to hide […]
The post Using TPF to Protect Sensitive Data in Grid Columns for D365FO appeared first on Alex Meyer.
