Источник:
https://ax.docentric.com/configure-s.../#comment-2158
Hi admin,I tried to To add the created certificate to the
Microsoft Dynamics ERP application on Azure, follow the 8 steps outlined in the beginning of the
Enable authentication with the S2S certificate from OneBox in AAD chapter. But Power Shell show errror at line "Connect -MsolService". I make sure that the
MSOnline module is already installed in the Windows PowerShell.Error in Power Shell.
Connect : The term 'Connect' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was included, verify that the path is correct and try again.At line:2 char:1+ Connect -MsolService+ ~~~~~~~+ CategoryInfo : ObjectNotFound: (Connect:String) [], CommandNotFoundException+ FullyQualifiedErrorId : CommandNotFoundExceptionPlease give me an advise.Thank you so much
Источник:
