Старый 27.05.2020, 21:14   #1
mark_brummel: Azure Application Insights 101
Источник: https://dynamicsuser.net/nav/b/mark_...n-insights-101
In my series around Application Insights for Microsoft Dynamics Business Central / NAV this is probably the most booring one. However it is quite important. In order to teach you folks about KQL and the Application Insights API etc. Step 1 – Create Application Insights In your Azure Tenant search for Application Insights and select Add. There is not much to fill in here. The Resource Group is probably most important if you have a bigger Azure Tenant. You want to group your stuff...(read more)
