Старый 16.04.2020, 01:15   #1
ax.docentric: Comment on Add a new parameter to SSRS reports in Dynamics 365 for Finance and Operations by Ana
Источник: https://ax.docentric.com/add-a-new-p.../#comment-1007
Dynamic query parameter that contains query ranges from the AOT query, which acts as the report dataset, will appear in the Records to include fast tab on the report dialog form, but only if you set the Dynamic filters property of the corresponding dataset to True before picking up the source query (for setting up the Query property of the dataset). On the other hand, if you set Dynamic filters to False, and then select (once again) your AOT query as Query of the dataset, the query ranges will be added directly to Parameters of the SSRS report. This means that they will also show up in the Parameters fast tab on the report dialog form when the report is printed. I didn’t test this myself but this is how it should work Kind regards, Ana
