Старый 11.11.2019, 22:14   #1
25,491 / 846 (79) +++++++
Alexdmeyer: Gaps in the Security Diagnostics for Task Recordings Feature in D365FO
Источник: https://alexdmeyer.com/2019/11/11/ga...ure-in-d365fo/
I have written in the past about how to use the Security Diagnostics for Task Recordings feature within D365FO to help determine the securable objects consumed during a recorded business process or task. But I found while diving deeper into using the tool that there are some gaps that you need to be aware of. […]
The post Gaps in the Security Diagnostics for Task Recordings Feature in D365FO appeared first on Alex Meyer.
