Старый 17.10.2019, 11:13   #1
Ventainais is offline
Ventainais
Unable to retrieve TypeId from DocuRef table for SSRS report
Good day.
My client needs a new report and for the report I have to check customer and vendor attachments.
When I test the table selection in a job, the DocuRef.TypeId has a value, but when I print the report the field is empty.
The report has no special design, it is just a simple table.
I need the TypeId for the if statement, but it looks as it never fetches the value.
I created a table "testTable" for testing to see what values are fetched and after I execute the report I see that TypeId is empty in all rows but the table DocuRef itself has no row with an empty TypeId field.
I am doing something wrong but I just can't see the error.
I hope you could help me.
Code below.
public void processReport()
    CustTable   custTable;
    VendTable   vendTable;
    DocuRef     docuRef;
    LogisticsPostalAddress          postalAddress;
    DirPartyLocation                    partyLocation;
    LogisticsAddressCountryRegion   addressCountryRegion;
    CustVendAC                      custVendAcc;
    utcDateTime                     startDateTime, endDateTime;
    TestTable_t    testTable;
    #define.SPP('URL')//TODO:Testing
    startDateTime   = DateTimeUtil::applyTimeZoneOffset(DateTimeUtil::getSystemDateTime(), DateTimeUtil::getCompanyTimeZone());
    endDateTime     = DateTimeUtil::addYears(startDateTime, -1);
   while select createdBy, createdDateTime, TypeId from docuRef
        where docuRef.RefTableId    == tableNum(CustTable)  &&
              docuRef.RefCompanyId  == curext()             &&
             (docuRef.createdDateTime >= startDateTime   &&
              docuRef.createdDateTime <= endDateTime     &&
              docuRef.TypeId == #SPP) || docuRef.TypeId != #SPP
        join AccountNum, Party from custTable
            where custTable.RecId       == docuRef.RefRecId     &&
                  custTable.Blocked     == CustVendorBlocked::No
        exists join partyLocation
            where partyLocation.IsPrimary   == true   &&
                  partyLocation.Party       == custTable.Party
        exists join postalAddress
            where postalAddress.Location == partyLocation.Location
        exists join addressCountryRegion
            where addressCountryRegion.CountryRegionId      == postalAddress.CountryRegionId    &&
                  addressCountryRegion.SanctionedCountry_mb == NoYes::Yes
        tmpCustVendListTable.clear();
        testTable.clear();
        if (custVendAcc != custTable.AccountNum)
            custVendAcc = custTable.AccountNum;
        else
            if (docuRef.TypeId != #SPP)
                continue;
        tmpCustVendListTable.BPAccountNum       = custVendAcc;
        tmpCustVendListTable.BPName             = custTable.name();
        testTable.BPAccountNum       = custVendAcc;
        testTable.BPName             = custTable.name();
        testTable.TypeId             = docuRef.TypeId;
        if (docuRef.TypeId == #SPP)
            tmpCustVendListTable.ResponsibleUser    = XUserInfo::find(false, docuRef.createdBy).name;
            tmpCustVendListTable.ScreeningDateTime  = docuRef.createdDateTime;
            testTable.ResponsibleUser    = XUserInfo::find(false, docuRef.createdBy).name;
            testTable.ScreeningDateTime  = docuRef.createdDateTime;
        tmpCustVendListTable.insert();
        testTable.insert();
