Старый 21.08.2019, 18:12   #1
ariste.info: Slow set-based operations?
Источник: https://ariste.info/en/2019/08/slow-...ed-operations/
In Microsoft Dynamics 365 for Finance and Operations we can execute the CRUD operations from code in two different ways, record-per-record or set-based. Microsoft’s recommendation is to always use set-based operations, if possible, as you can check on the Implementation Best Practices for Dynamics 365: Performance best practices for a successful Dynamics 365 Finance and … Continue reading Slow set-based operations? →
The post Slow set-based operations? was first published in ariste.info.
