Старый 24.06.2019, 15:11   #1
a33ik: Skip CIL execution
Источник: http://daxonline.org/1650-skip-cil-execution.html
To skip CIL execution for processes, which use SysOperation framework (SysOperationServiceController)
- set break point to \Classes\SysOperationServiceController\runOperation and track how many parameters do you have to identify which serviceClass.callObject to modify
- identify the type of proxy variable
In my case proxy is of type FormletterService and I have only one parameter, method returns value
- notice value of methodName variable to identify which method to call on the object, in my case it is postSalesOrderPackingSlip
- declare new variable of real proxy type, in my case it is FormletterService
FormletterService formletterService;- afteryour serviceClass.callObject write additional code like this one (depending onparameters count, return value and method to call)
if (false) { formletterService = proxy; operationReturnValue = formletterService.postSalesOrderPackingSlip(o1); }
- set break point to serviceClass.callObject
- in debugger move execution cursor inside your if statement
If execution of process if marshaled under specific user usingSysOperationRPCFrameworkService::runServiceOperation
Two solutions for that
1. Set break poin to \Classes\SysOperationServiceController\run
In debugger move execution cursor to one of the this.runOperation(false/*sync*/);
2. Modify \Classes\SysOperationRPCFrameworkService\runServiceOperation tothe following look:
public static container runServiceOperation(ClassId controllerClassId, container packedController){ // Use the runas API to transition to a CLR session new XppILExecutePermission().assert(); /* TODO: temp solution to debug issue return SysDictClass::invokeStaticMethodIL(classStr(SysOperationServiceController), staticMethodStr(SysOperationServiceController, runServiceOperation), [controllerClassId, packedController]); */ return SysOperationServiceController::runServiceOperation([controllerClassId, packedController]);}
