Старый 05.04.2019, 09:11   #1
ariste.info: Using Azure Application Insights with MSDyn365FO
Источник: https://ariste.info/en/2019/04/using...th-msdyn365fo/
First of all… DISCLAIMER: think twice before using this on a productive environment. Then think again. And if you finally decide to use it, do it in the most cautious and light way. Why does this deserve a disclaimer? Well, even though the docs state that the system performance should not be impacted, I don’t … Continue reading Using Azure Application Insights with MSDyn365FO →
La entrada Using Azure Application Insights with MSDyn365FO se publicó primero en ariste.info.
