Старый 29.03.2019, 18:11   #1
ariste.info: Generate number sequence values from REST services and OData
Источник: https://ariste.info/en/2019/03/gener...ces-and-odata/
One of the options to integrate MSDyn365FO with external systems is using the data entities with REST services and OData. To use OData the entity must have its IsPublic property set to Yes: Otherwise, if it´s an standard entity, we´ll need to duplicate it because it´s not possible to change the property value in an … Continue reading Generate number sequence values from REST services and OData →
La entrada Generate number sequence values from REST services and OData se publicó primero en ariste.info.
