Тема
axatoz: Using Postman with D365
08.03.2019, 01:23
1
848
80
Источник:
https://axatoz.wordpress.com/2019/03...man-with-d365/
We need the right tool for the job. Postman is a tool that often used to interact with Restful services (OData). Below is how you can setup postman to work with D365 (assuming you know how to setup on Azure side like tenant_id, client_id, client_secret)
SETUP
Setting up BearerToken
Params tab
Body tab
grant_type: {{grant_type}}
client_id: {{client_id}}
client_secret: {{client_secret}}
resource: {{resource}}
Test tab
var json = JSON.parse(responseBody);
tests[“Get Azure AD Token”] = !json.error && responseBody !== ” && responseBody !== ‘{}’ && json.access_token !== ”;
postman.setEnvironmentVariable(“bearerToken”, json.access_token);
TEST
OR
Postman with CRUD operations
Insert
Operation
Header tab
Authorization =
Bearer
{{bearerToken}}
If-None-Match = null
OData-Version = 4.0
Content-Type = applicatin/json
Accept = application/json
Odata-MaxVersion = 4.0
Body tab
Result
Источник:
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите
личное сообщение
администратору.
Посмотреть профиль
Найти ещё сообщения от Blog bot
