Старый 15.02.2019, 00:27   #1
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
Post D365FO Platform Update 22 (7.0.5095) KB 4486423 bug fixes
Дата выпуска: 23.01.2019 (был еще один выпуск PU22 - KB 4471117 от 20.11.2018, его вскоре после публикации убрали из общего доступа, вернув уже в декабре)
Список исправлений:
  • Issue 255228 Data Integration
    Dual write support for multiple company mapping between CDS and AX
  • Issue 259971 Develop and customize
    Type provider tests may generate unexpected Best Practice (BP) warnings
  • Issue 237566 Develop and customize
    Post-Event handlers on form methods are not triggered in some cases
  • Issue 247968 Intelligence
    Alert framework is not determining field level access rights correctly.
  • Issue 262343 Intelligence
    Dynamics365 On-premises: Something went wrong while generating the report
  • Issue 261104 Intelligence
    SSRS Reports fail to render in development environments.
  • Issue 247205 Localization and Regulatory features
    Wrong date format d.yyyy.MM when strFmt() is used with datetime fields in localization for Slovenia
  • Issue 231449 Localization and Regulatory features
    [Denmark] Danish label for “round-off” is incorrect, should be Afrunding
  • Issue 219120 Organization administration
    Error when creating a new Workflow work uerm queue assigment rule Cannot create a record in Workflow work item queue assignment (WorkflowWorkItemQueueExpressionDef).
    Document: TrvWorkflowExpHeader. The record already exists.
  • Issue 226525 Organization administration
    Unable to select document key in free text invoice sub-workflow
  • Issue 246152 Organization administration
    Workflow execution account setup is not working correctly
  • Issue 180310 Organization administration
    Workflow delegation gives unexpected results
  • Issue 262155 Runtime
    DatabaseSynchronize Event Provider Channel is not deploying
  • Issue 173920 Runtime
    Cannot edit a record in PCLUDFDateTimeValue (PCLUDFDateTimeValue). Data update is not allowed on a field that has not been selected.
  • Issue 262822 Runtime
    Cached table data methods exception handling.
  • Issue 259545 System Administration
    Enable sending AAD invitation email for B2B invitation
  • Issue 256702 Upgrade
    Data Upgrade fails on step 6 due to unrecognized additivetablesync parameter
  • Issue 252748 User Interface
    User sees an “Invalid value (XXXX*) specified in the query predicate” error when changing the filter operator in the Product Reservation hierarchy dropdown
