Старый 05.02.2019, 04:20   #1
axtoday: Chain of Command - avoiding the next call
Источник: http://axtoday.blogspot.com/2019/02/...next-call.html
This is possibly something that needs to be used very sparingly if at all, but apparently there is a way (up until the latest version - v8.1) to avoid calling the next() call when using chain of command.
The key is to use double nested conditions:
//this will not work "call to 'next' should be done only once and unconditionally"
protected voidchooseLinesPackingSlip(boolean _append)
If (true)
this.somethingElse(_append);
return;
nextchooseLinesPackingSlip(_append);
//this will work
protected void chooseLinesPackingSlip(boolean _append)
If (true)
if (true)
return;
next chooseLinesPackingSlip(_append);
