Старый 23.01.2019, 11:11   #1
ax.docentric: Comment on Append Terms and Conditions to printed Purchase orders or Invoices in D365FO by bablu
Источник: https://ax.docentric.com/append-term...o/#comment-643
Hi Jure ,Appreciate for your prompt response...I have added the above code for adding the subdocument and I have set the PO ddsp to my custom class CUSTPurchPurchaseOrderDSP_OverrideRRS which extends DocDataSourceProviderSrsReporting in the PO ddsp dropdown and have generated the new DDSP using print management settings. After loading the ddsp file I couldn't see the subdocument tag in the header dataset.One more question .. this subdocument feature will work only for attachments attached to the particular PO ?thanksbablu
