Источник:
https://www.tech.alirazazaidi.com/av...nd-operations/
Hi all, My fellow
Sohail Shaikh wrote an excellent blog Post, I used it in my customization to avoid overlay methods in some of out of the box table.
http://d365technext.blogspot.com/201...opment-of.html
That article made my day and worked perfectly fine. But here one thing that article missed. How we have to set form designer the custom workflow in list page . Something like If I copied from Sheiks sabs article.
There is error when I created on initialized of custom table in a extension class for list page . I got following error.
So it is not possible, I still not figure out. Later possible I will got they way to do so. Any how I achieved this in extension for interaction class. I copied the post event of initializeQuery method and copied in my class and following code will work for me. To enable or disabled workflow in list page
[PostHandlerFor(classStr(TableListPageInteraction), methodStr(ListPageInteraction, initializeQuery))]
public static void TableListPageInteraction_Post_initializeQuery(XppPrePostArgs args)
TableListPageInteraction TableListPageInteraction = args.getThis();
StatusTable RFQStatusTable = purchRFQCaseTableListPageInteraction.listPage().activeRecord(queryDataSourceStr(TableListPage, DDSRFQStatus)) as DDSRFQStatus;
FormRun formRun = TableListPageInteraction.listPage().formRun();
FormRun.design().workflowDatasource(formDataSourceStr(PurchRFQReplyTable, DDSRFQStatus));
FormRun.design().workflowEnabled(true);
FormRun.design().workflowType(workflowtypeStr(DSSRFQCaseWFType));
It works for me
Источник:
