Старый 12.10.2018, 22:13   #1
goshoom: Word document from code
Источник: http://dev.goshoom.net/en/2018/10/wo...ent-from-code/
Sometimes you may want to generate a Word document from code in D365FO, which gives you much more control over the result than if you simply printed a report to Word.
Here is a very brief example of how you can do it.
Start with creating an X++ project. Then add a C# class library to the same project. Right-click the C# project, use Manage NuGet Packages… and install DocumentFormat.OpenXml package.
Then add the following class:
using System.IO;using DocumentFormat.OpenXml;using DocumentFormat.OpenXml.Packaging;using DocumentFormat.OpenXml.Wordprocessing; namespace WordLib{ public class WordDoc { public Stream Create() { MemoryStream ms = new MemoryStream(); using (WordprocessingDocument wordDocument = WordprocessingDocument.Create(ms, WordprocessingDocumentType.Document, true)) { MainDocumentPart mainPart = wordDocument.AddMainDocumentPart(); string text = "Do androids dream of electric sheep?"; Body body = new Body(new Paragraph(new Run(new Text(text)))); mainPart.Document = new Document(body); } return ms; } }}
This code will create a very simple Word document, containing only a single line of text, and returns it as a memory stream. You would likely need something more complicated, but that’s out of scope of this blog post. You can get more information from Open XML SDK documentation.
Build the C# class library and we’re done with it; now we need to call it from X++.
Go to the X++ project, right-click References, chose Add Reference… and add a project reference to the C# library.
Then add a runnable class with the following code, which merely calls the library and returns the stream as a file to user:
class WordDocGeneratorSample{ public static void main(Args _args) { using (System.IO.Stream wordStream = new WordLib.WordDoc().Create()) { File::SendFileToUser(wordStream, 'file.docx'); } }}
Set the class as the startup object, run the project and your browser should offer you the Word document for download.
