Источник:
https://blogs.msdn.microsoft.com/axs...nd-operations/
In Dynamics 365 for Finance and Operations cleanup routines are available across various modules within the product. It is important to note that these cleanup routines should be only executed after detailed analysis and confirmation from the business this data is no longer needed. Also always test each routine first in test environment prior executing...
Источник:
