Старый 23.08.2018, 21:12   #1
emeadaxsupport: IDMF – Configuration Setting – UpdateMasterSyncTablesPostMetaDataSync
Источник: https://blogs.msdn.microsoft.com/axs...tmetadatasync/
Consider a scenario where you are using IDMF 2.0, and you find that after each IDMF Metadata sync the Master table list gets refreshed and you then have to manually sort out the list each time by unchecking/checking tables as Master tables. Well, there’s a simple way to change that default behaviour: 1. Update AXDataManagementSchedulerService.exe.config... Read more
