Старый 20.08.2018, 20:13   #1
d365technext: Edit Method D365FO
Источник: http://d365technext.blogspot.com/201...od-d365fo.html
Edit Method D365FO
In AX 2009, when reference control was not available, in table if there is a relation created on the basis of any field i.e. there is a child table and it contains the record Id of the parent Table. When that child table binds to form, (to display and select the user friendly information from the parent table, lookup controls were used). The record Id of the user friendly value is saved on the table with the help of the edit methods.
Here is the example to use Edit Method.
editint ageUpdate(boolean _set, int value)
SLD_DemoTable _demoTable;
int ret;
// find the car records from the car table with update = true
_demoTable = SLD_DemoTable::find(this.Name, _set);
if (_set)
ttsbegin;
_demoTable.Age = value;
_demoTable.update();
ttscommit;
else
ret = _demoTable.Age;
return ret;
