Старый 06.06.2018, 15:11   #1
emeadaxsupport: Error “The authorization token issuer is invalid. An identity provider with a matching issuer was not found in the system” upon MPOS activation
Источник: https://blogs.msdn.microsoft.com/axs...os-activation/
Upon activating MPOS you can run into the following error message that you would also see in Event Viewer: errorMessage The authorization token issuer is invalid. An identity provider with a matching issuer was not found in the system. In order to troubleshoot this you will need to look into the Event Viewer logs of... Read more
