Старый 21.04.2018, 17:13   #1
vanvugt: Let's talk about Shared Fixture and ... NAV 2018 CU4
Источник: https://dynamicsuser.net/nav/b/vanvu...d-nav-2018-cu4
Tomorrow exactly one month ago I wrote this post, based on the update in a number of test codeunits in NAV 2018 CU3: Let's talk about Shared Fixture and how to profit from this with the Dynamics NAV Test Toolkit. Just now I finished upgrading our test code to NAV 2018 CU4. It was a lot of work as I had to manually check a lot, but, wow, MS did an even greater job. The redesign introduced in CU3, and implemented on the first 100 test codeunits, now has been continued on an even larger number of test codeunits. Due to this I was able to revert our customization substantially:
Release
# Customized Test Codeunits
NAV 2018 RTM
532
NAV 2018 CU3
492
NAV 2018 CU4
200
Keep the good work going ... (as I have still 200 of 720 customized ;-)
