Старый 17.03.2018, 09:11   #1
crmtipoftheday: Tip #1088: Errors importing marketing list entity in Dynamics 365 v9
Источник: https://crmtipoftheday.com/1088/erro...namics-365-v9/
If you make changes to the marketing list entity in Dynamics 365 v9 and try to move your customization, you may receive an error importing the customization.
Solution:
  1. Extract the solution and open the customization XML file
  2. Locate the List entity in the XML file
  3. Add the following tag in the XML file:
1
4. Zip the solution and import it again
