Старый 03.02.2018, 21:13   #1
cleverax: D365FO: Using Bar codes, External codes and GTIN in Warehouse app to identify an item.
Источник: https://cleverax.wordpress.com/2018/...ntify-an-item/
In almost every workflow of the warehouse app you will be prompted to enter an item number to proceed further. We can consider options like: Design a label that has AX item number as a barcode that you can scan. However, this will require labeling the stock before you do anything in the system. Moreover, … Continue reading D365FO: Using Bar codes, External codes and GTIN in Warehouse app to identify an item. →
