Старый 12.01.2018, 19:12   #1
crminthefield: Update required to connect Dynamics 365 CRM for Outlook Client 8.x to Dynamics 365 9.x instances
Источник: https://blogs.msdn.microsoft.com/crm...9-x-instances/
With the release of Dynamics 365 Customer Engagement (9.0), older versions of TLS (1.0 and 1.1) connections will be blocked and only connections using TLS 1.2 will be supported. If you are connecting a Microsoft Dynamics 365 for Outlook client on version 8.x to a 9.x Dynamics 365 instance, an update will be required for...
