Старый 25.10.2017, 10:52   #4
trud is offline
trud
1,039 / 1635 (57) ++++++++
Записей в блоге: 1
все секунды на 4-5 замирает и ждет пока в правой части формы обновятся поля.
Кстати торможение может и от версии браузера зависеть. вот на коннекте народ пишет что в IE тормозит, а в Chrome все нормально
In our particular case, 11 fields were added to the grid on form CustTable using form extension. As result, we get troubles with performance (around 4-8 seconds to change the line on the grid). And what is interesting - even if we simply make this fields not visible, performance becomes better.
After investigation on the server side, we found out, that server is busy for less than 1 second, and all other time, there is a freeze on the client side. You can find network diagrams on the picture below.
Also, we found out that trouble is only in IE browser because in Chrome this form works fine (1.5 -2 seconds to change the line on the grid).
