Старый 14.09.2017, 13:11   #1
sinedax: AX 2012: Forms on opening hide behind in the back - 2° part
Источник: http://sinedax.blogspot.com/2017/07/...behind-in.html
Hi Guys
About this topic the Microsoft workaround in some case doesn't helped me.
So, below you can find the code that definitely fix the issue!
Modify the StartupPost method of the Application Class and add these two lines:
if (hasGUI())
Application::DisableWindowGhosting();
Lastly, created the "DisableWindowGhosting" static method like this:
client static void disableWindowGhosting()
DLL DLL;
DLLFunction DLLFunction;
container con = WinAPI::getVersion();
if (conpeek(con, 1) == 6) //Vista and Win7/Win2008R2 only
//this will disable window ghosting for this process only, for its lifespan only
DLL = new DLL("USER32");
DLLFunction = new DLLFunction(DLL,"DisableProcessWindowsGhosting");
DLLFunction.call();
That's it!
