Источник:
https://ievgensaxblog.wordpress.com/...ppprepostargs/
Recently we came across a scenario where we needed to check if a field has changed after super() in update method of a table. Back in the days of AX 2012 you could easily compare original field’s value with current using orig() method before super() and call necessary logic after.
public void update()
boolean myFieldHasChanged = this.MyField != this.orig().MyField;
super();
if (myFieldHasChanged)
this.doStuff();
}Now we want to do the same using extensions. We can create Pre and Post event handlers, but they are static, so we need a way to pass a value between them.
First option is to use static field, like it’s done in
RunBase extension example
public static class MyTableEventHandler
private static UnknownNoYes myFieldHasChanged;
[PreHandlerFor(tableStr(MyTable), tableMethodStr(MyTable, update))]
public static void MyTable_Pre_update(XppPrePostArgs _args)
MyTable myTable = _args.getThis() as MyTable;
if (myTable.MyField != myTable.orig().MyField)
MyTableEventHandler::myFieldHasChanged = UnknownNoYes::Yes;
else
MyTableEventHandler::myFieldHasChanged = UnknownNoYes::No;
[PostHandlerFor(tableStr(MyTable), tableMethodStr(MyTable, update))]
public static void MyTable_Post_update(XppPrePostArgs _args)
if (MyTableEventHandler::myFieldHasChanged == UnknownNoYes::Yes)
myTable.doStuff();
MyTableEventHandler::myFieldHasChanged = UnknownNoYes::Unknown;
}Another option is to use XppPrePostArgs as a vehicle for new parameter. XppPrePostArgs has collection of parameters under the hood, so nothing stops us to add one more and framework will take care of passing it between Pre and Post event handler!
public static class MyTableEventHandler_XppPrePostArgs
const static str myFieldHasChangedArgName = 'myFieldHasChanged';
boolean myFieldHasChanged = myTable.MyField != myTable.orig().MyField;
<strong>_args.addArg(MyTableEventHandler_XppPrePostArgs::myFieldHasChangedArgName, myFieldHasChanged);</strong>
<strong>boolean myFieldHasChanged = _args.getArg(MyTableEventHandler_XppPrePostArgs::myFieldHasChangedArgName);
</strong>
myTable.doStuff();
}Using one of these approaches you should remember that static fields apply to the class, not to instances of the class, so do not mix well with concurrency. Trick with XppPrePostArgs tightly depends on current implementation, that could be changed anytime and comes with no warranty.
To overcome this and other limitations of extensions capabilities Microsoft is introducing
Method wrapping and chain of command and I’m pretty sure that we’ll see blogs on this from my MVP fellows soon.
Источник:
