Старый 19.06.2017, 18:46   #1
smailik is offline
smailik
Аватар для smailik
250 / 70 (3) ++++
Query я подправил. Сейчас без InventTable работает, а вот с ней висит на подсчете количества
query = new Query(querystr(myQuery));
    SysQuery::findOrCreateRange(query.dataSourceTable(tableNum(InventTransferTable)), fieldnum(InventTransferTable, ReceiveDate)).value(strfmt('%1..%2', 20\05\2017, toDay()));
    SysQuery::findOrCreateRange(query.dataSourceTable(tableNum(InventTransferTable)), fieldnum(InventTransferTable, TransferStatus)).value(QueryValue(InventTransferStatus::Received));
    SysQuery::findOrCreateRange(query.dataSourceTable(tableNum(InventTransferTable)), fieldnum(InventTransferTable, InventLocationIdFrom)).value('242');
    if (inventLocationType != InventLocationType::Standard)
        qbrDataAreaId = SysQuery::findOrCreateRange(query.dataSourceTable(tableNum(InventLocation), 2), fieldNum(InventLocation, DataAreaId));
        qbrDataAreaId.value(strFmt('((%1.%3 = %4) || (%2.%3 = %4))',
            'InventLocationTo',
            'InventLocationFrom',
            fieldStr(InventLocation, InventLocationType),
            any2int(inventLocationType)));
    s = query.datasourceno(1).toString();
    info(s);
    queryRun = new QueryRun(query);
    iRowCountTmp = SysQuery::countLoops(queryRun);
Без InventTable
SELECT * FROM InventTransferTable WHERE ((ReceiveDate>={ts '2017-05-20 00:00:00.000'} AND ReceiveDate<={ts '2017-06-19 00:00:00.000'})) AND ((TransferStatus = 2)) JOIN * FROM InventLocation WHERE InventTransferTable.InventLocationIdTo = InventLocation.InventLocationId JOIN * FROM InventLocation WHERE InventTransferTable.InventLocationIdFrom = InventLocation.InventLocationId AND ((((InventLocationTo.InventLocationType = 3) || (InventLocationFrom.InventLocationType = 3))))
С InventTable
SELECT * FROM InventTransferTable WHERE ((ReceiveDate>={ts '2017-05-20 00:00:00.000'} AND ReceiveDate<={ts '2017-06-19 00:00:00.000'})) AND ((TransferStatus = 2)) JOIN * FROM InventLocation WHERE InventTransferTable.InventLocationIdTo = InventLocation.InventLocationId AND ((((InventLocationTo.InventLocationType = 3) || (InventLocationFrom.InventLocationType = 3)))) JOIN * FROM InventLocation WHERE InventTransferTable.InventLocationIdFrom = InventLocation.InventLocationId
Тип файла: xpo myQuery.xpo (3.8 Кб, 404 просмотров)
