Старый 31.05.2017, 12:55   #2
bagamax is offline
bagamax
netframework 3.5.1 стоит
distr в c:\dax - не помогло
лог в районе ошибки:
(пробовал подсунуть длл в этот путь из другого языка, или выкинуть совсем - не помогло)
MSI (s) (B0:80) [11:04:11:304]: Executing op: AssemblyCopy(SourceName=-45f2g9r.dll|AxPrereqChecker.resources.dll,SourceCabKey=_AXPRER_1.DLL.ae3b.8D436F9A_4DC3_4156_A816_0F8ECA000CD6,DestName=AxPrereqChecker.resources.dll,Attributes=512,FileSize=57344,PerTick=65536,,VerifyMedia=1,,,,,ComponentId={E9CE6F0D-DBE6-4296-AE3B-4B25DD4DEED4},IsManifest=1,,,AssemblyMode=0,)
MSI (s) (B0:80) [11:04:11:304]: Source for file 'AxPrereqChecker.resources.dll' is uncompressed, at 'C:\dax\MSI\SetupSupport64\globalassemblycache\globalassemblycache\AR\'.
MSI (s) (B0:80) [11:04:11:414]: Assembly Error:The module '%1' was expected to contain an assembly manifest.
MSI (s) (B0:80) [11:04:11:414]: Note: 1: 1935 2: 3: 0x80131018 4: IStream 5: Commit 6:
MSI (s) (B0:80) [11:04:11:414]: Note: 1: 2337 2: 0 3: AxPrereqChecker.resources.dll
MSI (s) (B0:80) [11:04:28:449]: Product: Microsoft Dynamics AX 2012 Setup Support Files (64 bit) -- Error 2337. Could not close file: AxPrereqChecker.resources.dll GetLastError: 0.
MSI (s) (B0:80) [11:04:28:496]: Internal Exception during install operation: 0xc0000005 at 0x000007FEEE9A717B.
MSI (s) (B0:80) [11:04:28:496]: WER report disabled for non-console install.
MSI (s) (B0:80) [11:04:28:496]: Internal MSI error. Installer terminated prematurely.
MSI (c) (90:70) [11:04:11:445]: Font created. Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
