Старый 29.05.2017, 18:41   #8
belugin is offline
belugin
Аватар для belugin
4,622 / 2925 (107) +++++++++
Записей в блоге: 5
https://www.infoq.com/articles/monolith-defense-part-1
Key Takeaways
  • Both monoliths and microservices are viable architectures, though a monolith must be modular to be sustainable. Monoliths probably fit better for complex domains (enterprise apps), while microservices are more suited to internet-scale applications with simpler business domains.
  • Going with a microservices architecture means foregoing both transactions and referential integrity across modules/services. This necessarily comes with an implementation cost.
  • Either architecture requires a platform to support it. For microservices, much of the support relates to the complications that a network introduces (for example circuit breakers). For monoliths, the platform needs to handle cross-cutting technical concerns to allow the developer to focus on the complexity of the domain.
  • Going “Monolith First” (building the application as a modular monolith initially with the aim of breaking it into microservices later) requires that the modules’ boundaries, interfaces and responsibilities are well-defined.
За это сообщение автора поблагодарили: ax_mct (5).
