Старый 02.03.2017, 20:11   #1
stephenmann: Can't install CDX Async server / Realtime on Windows 10 or Server 2016?
Источник: https://www.stephenmann.net/single-p...or-Server-2016
Exception             : System.MissingMemberException: Error while invoking GetType. Could not find member.
At "AddOrRemoveUserToNTGroup" in Common-Configuration.ps1: line 692
When installing AX Async service and Realtime service on Windows 10 machines the installer will fail.  When trying to install through powershell then can the the below error:
There is a couple of try/catch statements that can be added to the Common-Configuration.ps1 file to get past these errors, after this the script will continue past the error and complete the setup.
