Старый 20.02.2017, 20:12   #1
organicax: RFQ Reply defaults
Источник: https://organicax.com/2017/02/20/rfq-reply-defaults/
When you setup an RFQ you have the option to specify what fields you might want to default onto the vendors bids for example the prices. There is a few parameters called reply defaults that you can setup in procurement and sourcing parameters as well as override them on a specific RFQ.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Procurement and sourcing
