Старый 28.12.2016, 16:11   #1
Kashperuk Ivan: Configuration tip: Warehouse mobile devices portal Native application in Azure Active Directory
Источник: http://kashperuk.blogspot.com/2016/1...se-mobile.html
Setting up the Warehouse mobile devices portal is a relatively simple process, and is described in detail on the corresponding wiki:https://ax.help.dynamics.com/en/wiki...ics-ax/However, now and again I would get complaints around the authorization process not working properly, or asking for interactive login, both of which shouldn't be
