Старый 19.12.2016, 12:11   #1
msdn.microsoft.com/nav: How to export a Dynamics NAV database on SQL Server 2016
Источник: https://blogs.msdn.microsoft.com/nav...l-server-2016/
If you use SQL Server 2016 for your Dynamics NAV database, and you need to export a database to the .bacpac format, then please make sure that you are running the latest update (August 2016 update or later) of the Microsoft SQL Server Data-Tier Application Framework (DacFx) or SQL Server Management Studio (SSMS). If you...
