Старый 21.11.2016, 13:02   #1
AnGor is offline
AnGor
Аватар для AnGor
97 / 46 (2) +++
Записей в блоге: 6
Сообщение от Pandasama Посмотреть сообщение
В веб.конфиге попробуйте что-нибудь типа
Код:
<security mode="Transport">
<transport clientCredentialType="Windows"/>
</security>
так тоже пробовал. При таких утановках сервис даже в браузере не открывается (http://localhost/MicrosoftDynamicsAX...andservice.svc)
вот что в ивентах:
WebHost failed to process a request.
Sender Information: System.ServiceModel.Activation.HostedHttpRequestAsyncResult/40550573
Exception: System.ServiceModel.ServiceActivationException: The service '/MicrosoftDynamicsAXAif50/inventoryonhandservice.svc' cannot be activated due to an exception during compilation. The exception message is: Could not find a base address that matches scheme https for the endpoint with binding WSHttpBinding. Registered base address schemes are [http].. ---> System.InvalidOperationException: Could not find a base address that matches scheme https for the endpoint with binding WSHttpBinding. Registered base address schemes are [http].
at System.ServiceModel.ServiceHostBase.MakeAbsoluteUri(Uri relativeOrAbsoluteUri, Binding binding, UriSchemeKeyedCollection baseAddresses)
at System.ServiceModel.Description.ConfigLoader.LoadServiceDescription(ServiceHostBase host, ServiceDescription description, ServiceElement serviceElement, Action`1 addBaseAddress)
at System.ServiceModel.ServiceHostBase.ApplyConfiguration()
at System.ServiceModel.ServiceHostBase.InitializeDescription(UriSchemeKeyedCollection baseAddresses)
at System.ServiceModel.ServiceHost..ctor(Type serviceType, Uri[] baseAddresses)
at System.ServiceModel.Activation.ServiceHostFactory.CreateServiceHost(Type serviceType, Uri[] baseAddresses)
at System.ServiceModel.Activation.ServiceHostFactory.CreateServiceHost(String constructorString, Uri[] baseAddresses)
at System.ServiceModel.ServiceHostingEnvironment.HostingManager.CreateService(String normalizedVirtualPath)
at System.ServiceModel.ServiceHostingEnvironment.HostingManager.ActivateService(String normalizedVirtualPath)
at System.ServiceModel.ServiceHostingEnvironment.HostingManager.EnsureServiceAvailable(String normalizedVirtualPath)
--- End of inner exception stack trace ---
at System.ServiceModel.AsyncResult.End[TAsyncResult](IAsyncResult result)
at System.ServiceModel.Activation.HostedHttpRequestAsyncResult.End(IAsyncResult result)
Process Name: w3wp
Process ID: 5528
