Старый 17.09.2016, 07:30   #1
organicax: Item coverage setup wizard
Источник: https://organicax.com/2016/09/16/ite...-setup-wizard/
If you are setting up item coverage and you need to do it for multiple sites and warehouse then creating the entries manually could be time consuming. Luckily there is a wizard that might be useful to leverage that would save a bit of data entry time.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Supply chain planning
