Старый 12.08.2016, 17:11   #1
palleagermark: Don't change the name of a Form instance in AX 7
Источник: http://www.agermark.com/2016/08/dont...nce-in-ax.html
In AX 2012 you could do something like this, where you change the name of a Form instance:
form = new Form(formstr(MyPrettyForm));
form.name("AnotherNameToConfuseEverybody);
args = new Args();
args.object(form);
formRun = classfactory.formRunClass(args);
etc...
In AX 7 changing the name seems to confuse AX to a sense where it can't figure out to actually run eventual code in (at least) the init and run methods of the form.
For many reasons I think it is a poor idea to change the name of a form instance, now there is also a technical reason not do it.
