Источник:
https://channel9.msdn.com/blogs/Mach...r-Dynamics-CRM
Microsoft team has released a Opportunity Scoring solution.
Opportunity scoring uses a machine learning model trained on past sales data to predict the eventual probability that the sale will be won. Training and prediction are implemented with
Azure Storage and
Azure Machine Learning, orchestrated by
Azure Scheduler, and executed within an
Azure Web Job.
Where to download opportunity scoring
Download is available at
http://opportunity.codeplex.com/
Click to
download
What does download provide – opportunity scoring solution
1. The download provides an advanced solution reference architecture that a IT developer can customize to build customized end-to-end solutions.
2. The documentation has step-by-step instructions to guide you through the installation.
3. Once installed you will see three Machine learning models, plus web services, endpoints, and retraining and scoring web jobs in your Azure ML subscription.
4. You will also see customizations applied to your Dynamics CRM instance to allow users to refresh their scores, view explanations why the opportunity got its score and view the history of previous scorings of opportunities
Источник:
