Старый 10.05.2016, 10:11   #1
organicax: Assigning a WMS work template to a disposition code
Источник: https://organicax.com/2016/05/09/ass...position-code/
In a previous post we had a look at creating warehouse disposition codes. You can use these to  do different processes in the warehouse for example based on the disposition code use a different work template. For example when someone in the warehouse is receiving goods then based on the disposition code you could move the incoming goods to a different location or have those goods handled by a different person. For this to happen for you will need to setup a work template and related it to the disposition code.
Here is a quick overview.
AX2012 R3 CU9.
Cheers
Lachlan
Filed under: Warehouse management
