Старый 18.11.2013, 14:25   #1
This is a follow up on the blog entry Coming soon – Commerce Gateway for Microsoft Dynamics NAV 2013.
We have released a sample application which illustrates how a get a Commerce Gateway solution to work in Microsoft Dynamics NAV 2013. The same solution will apply to Microsoft Dynamics NAV 2013 R2.
The sample shows how you should set up the connection between Microsoft BizTalk and Microsoft Dynamics NAV using a web service. To get the bits for the sample, request hotfix 2892792 from Microsoft Support.
The KB contains the following:
  1. A whitepaper describing the required steps to get the solution to work on Microsoft Dynamics NAV 2013, including how to change the upgrade tool to keep the Commerce Gateway objects as well as suggested code changes to make all objects work. The whitepaper also includes a description on how to change the BizTalk setup.
  2. A .fob file with some of the objects to make the solution work. Please note that it is only a subset of the Commerce Gateway solution, mainly the communication objects. This includes a new code unit to be exposed as a web service.
  3. A Microsoft Excel sheet showing all objects that are relevant for Commerce Gateway as well as an identification of the objects that have changed.
  4. Please note: The solution still utilizes the Commerce Gateway Request Client and the Request Server in the Microsoft Dynamics NAV 2009 version, so the limitations for a 32 bit installation are still true.
Rikke Lassen
Senior Program Manager
Источник: http://feedproxy.google.com/~r/Micro...-nav-2013.aspx
